AEG competence oven
  • #46645
    loosefit
    we have a 5 year old oven, the door is not closing tightly, hinges are located properly, any suggestions as to what is wrong ?
    #290319
    Re: AEG competence oven
    Model number, please, and preferably the pNc number as well.
    ade_63
    Although hinges may appear OK they may well need replacing as springs do gradually fail. May well need new runners (the mechanism that hinges locate into) as well as bearings can also fail.
    I would try new hinges initially.
    #290321
    gandh1
    ade_63 wrote: I would try new hinges initially.
    elux hinges generally £30 for a pair if not obsolete! – worth a go as P45 said tho – PNC/Prod no/ or PR No. for a more accurate quote. 9 or 11 digit code that will start with a 9XX XXX XXX (XX) usually located printed between the model number and serial code! hope that helps!
    #290322
    loosefit
    Thanks everyone for the advice, PNR no is 944181757, where’s the best place to buy hinges?
