AEG Competence oven
  • #50550
    lholmes
    My AEG Competence B2100-1 PNC 944 181 731 cuts out about 20 minutes after switching it on. Fan totally stops and works again after switching off and letting the oven cool down.
    Any help/advice on how to fix this would be appreciated.
    #305238
    Re: AEG Competence oven
    Usually THIS LITTLE CHAPPIE is the culprit. Switches cooling fan on. If it doesn’t, overheat stat shuts the oven down.
    It’s under the top cover panel – power off first.
    lholmes
    Thank you
    #305240
    syab
    I’ve just bought and replaced the same unit but still have same problem, except it now last 25 mins instead of 20.
    Any ideas ? was wondering if the new unit was faulty as the old one was very brown and burnt so clearly a good suspect as to the fault.
    Brian
    #305241
    Comes back to the same basic question – does the cooling fan run or not? The new inductor is unlikely to be faulty – Electrolux up-dated them two or three years ago due to a high failure rate.
