AEG Competence oven cutting out
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Competence oven cutting out
  • #93671
    Bobbyjobby
    My oven is cutting out after about half an hour. Everything stays on but no heat and fan. Same thing happens with grill.
    AEG Competence
    B4100 -1 -a
    PNC 944 181 681
    #455201
    Re: AEG Competence oven cutting out
    common fault with these ovens is the cooling fan
    there is a control in the oven that starts the fan about 3 mins after it is turned on and switched it off about 10 mins after use
    if you fan is running you will feel warm air at the top of the door when its on. If not it will cutout as it will overheat the control area
    part you should require is
    899661 92 67-61 / 1
    https://shop.ukwhitegoods.co.uk/8996619 … an-control
    I cant promise I am right without an inspection but its a very common fault changes one last week
    Shilo
    Hi, I’m new to this so apologies as I’m not sure if I’m posting in the right place?
    When using our AEG Competence double oven (model DE40003000M) last night it just stopped working. No heat, fans or clocks displaying. Nothing had tripped at the fuse board and the oven socket feeding the cooker was working fine powering a radio.
    Any ideas?
    #455203
    well I would still check the main connections to the oven first
    Shilo
    Thanks Dave. All the cables feeding in and out of the cooker socket looked fine to me (nothing was loose)? I haven’t removed the oven from the housing though.
    #455205
    there will be a terminal block where the flex connects to the oven this is the first thing to check
    Shilo
    good call Dave. Called an electrician out and the terminal block had melted!!!
    #455207
    2 listed for that oven
    3 pole part no 3192553018
    6 pole part no 3192554016
    if its got 3 connections its 3 pole etc
    you may have difficulty as the oven is 18 years old
