AEG Competence Switching off
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Competence Switching off
  • #69450
    DaveGUK
    Hi Guys
    I have a AEG B4101-1-m single oven
    PNC A944-181-743
    It has started to switch off intermittently, but this doesn’t seem to be the same as the overheating scenario usually reported here.
    Symptoms, Sometimes when in use for 1 or 2 hours it switches off, front led indicators stay on, timer stays on, but oven light and all fans switch off. usually it restarts moments later, if it doesn’t a simple tap on the front or open close door starts it again, sometimes it goes off again after 10 seconds, sometimes it runs for another 20 mins, no signs of overheating, door and front panel all stay cool to touch.
    Have opened it, cleaned it checked all spade connections, made sure all circuit board connectors are fully home, can’t see any signs of overheating on cables or sensors.
    Problem still remains
    Haven’t pulled the master circuit board yet, that’s next, but thought you may be able to advise what else to check.
    My gut says heat related physical problem, dry joint on circuit board or dodgy stat sensor, but nothing obvious and no previous posts with these symptoms, any suggestions appreciated, even if it’s just “time for new oven”
    DaveG
    #374848
    Dicky board sounds like…. 🙁
    #374849
    johnnyj
    Re: AEG Competence Switching off
    Could be the thermal cut out
