AEG Competence top oven knob and indicator dial
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts AEG Competence top oven knob and indicator dial
  • #7064
    Simon46
    Hi all
    Am after a top oven selector knob and the indicator dial which is behind the glass panel (RHS end of facia). Someone has seen fit to lose the little metal insert in the knob, fit a makeshift one out of thicker metal and pushed it on so hard it pushed the selector switch out of the clips on the front facia panel, cracking the bush that shows the element selection. Numbers are:
    Competence 52381 B-M
    PNC 944183016
    S/No 93005618
    Type 56EKH43GD
    How much and how long will it take to arrive?
    Cheers
    Simon
    #121230
    Simon,
    P/nos are:
    Knob – 8996611947-17/8
    Disc – 8996613911-85/9
    Didn’t come up on any of the wholesalers sites, so presumably special order.
    Simon46
    Re: AEG Competence top oven knob and indicator dial
    Chris, do you know if the disc with the symbols on comes complete/attached with the bush that slides onto the shaft? What i mean is its not just a piece of paper?
    cheers
    Simon
    #121232
    Si,
    The diagram shows three parts – the knob, the circular inner indicator disc (“scale disc” – so presumably printed) and a larger circular fitting called the reflector, which would appear to surround the whole sheebang.
    You may wish to torment your customer by pointing out that the knob insert is available as a spare as well – 8896613013-00/3. 🙄
    Hope that helps,
    Simon46
    Been down to local supplier to see exploded view to clarify. Shown on electrolux website it appears that the insert that slides onto shaft is no longer available? is this the case with yours Chris?
    Regards
    Simon.
    #121234
    Si,
    I’ve listed off all four of the parts relating to the knob assembly – as far as the TDS system is concerned they all appear to be valid part numbers.
    Perhaps Dave C or one of the Service force lads could double check for you in the morning?
    You now know as much as I do!
    Dave_Conway
    Yep, correct Simon.
    8996613911-85/9 (the indicator) is now obsolete.
    #121236
    Simon46
    Thanks Dave/Chris. Oh well. Looks like another job in the bin. Nice S/S oven as well.
    Cheers
    Simon
