Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG cooker B4100-1-d Fan Running Continuously
- This topic has 4 replies, 3 voices, and was last updated 20 years, 7 months ago by
bobokines.
August 18, 2005 at 11:24 am #11396
bobokines
ParticipantProd code 944181737
Can someone please confirm the part number for the cooling fan thermostat on this oven. It’s the tiny stat taped to the harness with two white and two blue wires.
I think it’s 8996619265482
It’s nil stock and I don’t want to let my customer wait and then find it’s the wrong bit
Many thanksBob
August 18, 2005 at 3:01 pm #145205Dave_Conway
ParticipantRe: AEG cooker B4100-1-d Fan Running Continuously
It’s part number 8996619267611 Bob.
To confirm, have a look at the product in the shop:
http://shop.ukwhitegoods.co.uk/89966192 … an-control
That’s the one isn’t it ?
August 18, 2005 at 6:35 pm #145206bobokines
ER? the picture looks like four amp tags leading nowhere?
Thanks for that, The part has been fitted before and the customer has a ServiceForce invoice with that part number on it.
thanks again Dave
Bob
August 19, 2005 at 8:37 pm #145207eastlmark
ModeratorRe: AEG cooker B4100-1-d Fan Running Continuously
Yep, that picture has to win the most useless part picture of the year!
Actualy, we are fitting loads of these right now, usual complaint being the oven cutting out completely when hot as the cooling fan is not being initialised. ID of this part is not helped by it not being shown on TDS or Pro corner and it being offically described as a “thermal cut out” which it is not. It first appears to be just a join of 4 wires but is infact a tiny heater strip wired in series with the oven fan element, the current for which heats up a bi-metal strip that initialises the cooling fan motor after a while. The object being that even when the oven is turned off, the cooling fan will continue to run until the bi-metal cools down and breaks to circuit. Simpl? yes, cheap? yes, reliable? NO.August 19, 2005 at 9:36 pm #145208bobokines
It obviously fooled the ServiceForce engineer on this machine as he fitted FIVE components on the previous invoice for the same fault ❗
Thanks for the explanation.
Bob
