The motor on my AEG HD 6470-M cooker hood is slow to start spinning when switched on and when it does start up it runs for a a couple of minutes then starts to slow down considerably until it ceases to be effective although it never actually stops. Which components should I replace to get it back to normal please.
Thanks for the reply. I ordered the part that you recommended and it came today. The arrangement of the connection tags is slightly different on the new one – there are four instead of two – which ones do I use please?
I took a risk and connected the wires up in what I believed was the correct way to the new capacitor and you will be pleased to hear that the motor is now running as it should again!! Thanks once again for you valuable help – it was much appreciated.
Cheers
Delks
