f44070id pnc 91123521401. been out to this a couple of times now, customer complains about water in front of door. i have changed top seal and lower seal looks ok. has any one had this fault before. you can see its been leaking out of door but everytime i run it, it dont leak im wondering if old girl is spilling water on floor
Had a few AEG d’washers with door catch problems, when circulation pump comes on the force of water slightly pushes door open enough to allow leakage. I adjusted tension of spring on lock & it cured problems.
