91153904302
Program starts then after a couple of seconds the flooded base error starts. 3 flashes and continuous draining. Seems to be a fault with the float micro switch but am wondering if it could’ve damaged the board.
When I test the switch it’s open circuit until I press the button but then gives fluctuating readings. I’ve tested the machine with switch disconnected (open circuit) and connected and it still activates the flooded base error when you start the program starts after a few seconds either way. I’ve checked for broken wires. Board?
Subs
