AEG D/W (Pnc 911 232 407 01)
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts AEG D/W (Pnc 911 232 407 01)
  • #43222
    rocker
    The mains filter (suppessor fitted to motor. 0.27uf) has blown.
    this part isn’t available as a spare from aeg, anyone known were I may be able to buy one.
    John.
    #276472
    Re: AEG D/W (Pnc 911 232 407 01)
    This is only 0.15uf but it seems to be extremely small so maybe you could fit two in parallell :?.
    http://www.maplin.co.uk/module.aspx?moduleno=501
    Mike.
    Edit: Doh!, I was reading the tolerance from the diagram (+/- 2mm) as the dimension. It’s 35mm x 14mm dia, but you could probably sill find space for two as the leads are longish.
    #276473
    Seamy
    899646 13 37-30 / 6 capacitor
    899646 14 44-49 / 0 anti interference filter
    #276474
    rocker
    Thanks to you both for your advice, will look into these thanks John.
