Re: AEG D4100-1 cooling fan noisy
Assuming that this is an “axial” fan, it may well respond to a good clean and a drop of oil. You’ll have to get the oven out of the housing to access it through the top cover, though. Two man lift……. Cut the power before attempting to move it.
If there is play on the motor bearings, the unit will have to be replaced. We’d need the Pnc number to identify the exact part required, as there are over 30 D4100 models.
Penguin45,
