Went too this oven which was cutting out after 15 mins or so. All the display is going out and all oven functions stop.
The cooling fan was not coming on because the 45c stat was not functioning so ive replaced this and now the cooling fan is working a treat but it is still cutting out after 15 mins. Apart form the 180c stat at the rear of the main oven is there anything else that could be causing this??
hi simon is there a cooling fan control on this oven did you check it. that keep the front control panel cool if it is burnt looking that could be your problum fasetester.
