Hopefully an easy one, been to see an AEG D4101 today which isn’t hitting temperature on the main oven, seems to fail at 50 below the required temperature.
Can any of you provide me with a part number for the thermoststat?
before ordering thermostat did u check whether there was a guard
over the fan on the backplate of the oven?
if there is remove it & check temp again.
I`ve seen a few where this gets covered in grease and causes the stat to
cut out before the oven has reached proper temp.
