AEG D5701-4 Lower oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG D5701-4 Lower oven
  • #97231
    Bessy bubbles
    Hi guys,
    My lower oven does not reach the higher temperature … please would someone tell me what the problem might be, could it be the temperature switch etc?
    I’m not sure if it is a fault code, but when we switch the oven on/off the display reads 047 191.
    Any help would be much appreciated and thanks for reading.
    Kind regards,
    John.
    #466614
    this oven has various settings so which type of oven are you haveing problems with
    there is normally an indicator that tells you when the selected temp is reached is this indicating if it thinks its beenm reached ?
