The above oven has an the following problem:-
Turn the fan oven (cust says she only uses fan oven), Works o.k for a while then the oven turns off and starts back at the beginning (rather then displaying the temp its just showing the time) Cust says it does this a random times into cooking and you can just set it back cooking and off it goes fine untill it does it again, She also says its an intermittent fault, i was there with it running for about half an hour with no probs, The cooling fan seems to cut in and out as req, the stats seem fine, All the connections on the Pcb’s seem o.k.
Any Ideas?
Thanks in advance guys.
