AEG D8100-M Top oven cuts out
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG D8100-M Top oven cuts out
  • #23346
    linaceng
    Hi I have the above oven. The top oven cuts out and I’m guessing from what I read on here that likley to be the thermal cut out (na d not the fan init stat that turns the fan on when you are using the bottom oven as this works fine).
    Oven product code 9441171162 s/n 20600006
    Can anyone verify the part required? 89966192676-11??
    Another thing, the likely pic in the shopsite doesnt enlarge so without taking the oven out I cant see what I am buying. It looks like a resistor/thermal fuse shaped component enclosed in a plastic shroud with some wiring and crimps. Isn’t the core component an industry standard one that can be replaced from Farnell/RS for a few pence? 😉 (At your own risketc…)
    Thanks for the help
    #197823
    linaceng
    Re: AEG D8100-M Top oven cuts out
    Everyone on holiday??
    #197824
    Simon46
    The oven will need looking at first to confirm top cooling fan not running. Remove power from oven if you are going to look yourself.
    Regards
