AEG D8800 4 M 944171392
  • #73442
    ChrisR
    Hi guys
    Got one of these with a intermittant fault were the main oven fails to reach temperature.
    The fan element operates fine along with the fan and when i tested it it worked ok to 150c but when advanced to 200c it only reached 180c but my oven thermometer registered 200c.
    The probe is connected to the pcb via a cable.
    Are there any known heat faults on this model?.
    Regards
    Chris
    #387515
    Re: AEG D8800 4 M 944171392
    Only option open to you is to replace the sensor as I believe the PCB is obsolete.
    #387516
    ChrisR
    Yes your right Martin.
    User said its only 4 years old
    He’s not going to be happy
