AEG dishwasher
  • #101420
    SWERV
    I try to steer clear of dishwashers, but this one is for a friends dad and I said I’d take a look.
    I don’t have the model info, but they are saying that there is an error code showing I44, does anyone have any pointers as to what I should be looking for.
    Merv
    #484659
    I4 codes are all about pressure sw
    I41 is no signal from pressure sensor
    could just be blocked, some early units had a mod to stop blocking
    if you get model and pnc the I can send you the info
    SWERV
    Thanks Dave, I’m going to look a t it tomorrow.
    #484661
    SWERV
    Sorry for the late reply on this one.
    The pnc is 91153641800. The side chamber had a leak and it was also blocked. I replaced the chamber and also the pressure switch as I couldn’t get it to clear the fault. I checked for any further blockages but couldn’t find any. I ran it through a couple of rinses and also a quick 30 min cycle and all appeared fine.
    I got a call this morning to say that it is showing I44 again.
    Any pointers?
    Merv
    #484662
    i44 is
    and
    MCF = Machine Configuration File
    SWERV
    Thanks.
    Other than checking the wiring to the pressure switch, it could be a board fault.
    #484664
    SWERV wrote:Thanks.
    or the pressure switch
    SWERV
    I have already replaced the pressure switch.
    Merv
