hi I have an AEG 60870 SENSORLOGIC turns on set program, then it starts to pump then nothing no noise from the valve just dead it does count down the wash time remaining. 😕
just a stab in the dark, but have you checked the door switch? some of those AEG’s still run the drain pump even if door is open but will do nought else.
