Re: AEG Dishwasher 545 ENr 606 281 387
Assuming its not had one before (you can tell by the rubber tube and 2 jubilee clips connecting it to the tub) you have to cut the old one off (Hacksaw!) to replace it. It comes as a kit with the afformentioned rubber tube and clips. Its not tricky to change but you need to take the side and base off and make sure the door spring clears the chamber before putting the side back on (open and shut the door to test) and make sure no water leaks into the drain pump plug as it will go bang if it does. Up to a couple of years ago we were changing these often 2 times a day everyday and then doing it again 18 months-2 years later, it was a good earner, sadly now done rarely.
Sorry, no part number to hand, and I am away tommorrow, I am sure someone else will post it before then, about £30= vat.
