AEG dishwasher code 30
Home Forums Public Support Forums Help And Support Dishwasher Help Forum AEG dishwasher code 30
  • #84985
    Zaffy
    I have a small AEG Favorit Proclean dishwasher.
    On three occasions the code has flashed 30.
    The first time it happened, I tilted the machine and water came out of the bottom and all was okay.
    The second time it happened this trick did not work and so I undid the outlet hose from underneath the sink and stuck it out the window and tilted it again. This sorted it out and the machine ran fine for a couple of weeks.
    Today the machine is playing up again. Midway through the cycle it flashed code 30 again. I turned the machine off and tilted it again, turned it back on and it seems to be going okay now but is there anything I can try before it happens again? Thanks for reading and thanks in advance for hints, tips and advice.
    #427369
    Re: AEG dishwasher code 30
    you have to find the leak. the base has a float so if it leaks it shuts the unit down to stop flooding.
    you have to take the sides off the unit and look for the leak that is filling the base
    Zaffy
    Thanks, Dave, for your quick reply. Tomorrow I will look for the intermittent leak. I hope you find better things to do with your Sunday.
    #427371
    Zaffy
    A quick update, the cycle has just finished and all is absolutely fine but I will still take a look at the inside of the dishwasher because the problem is bound to happen again.
    #427372
    yes sunday busy day my sons 10th birthday. lots of kids all day lol
    Zaffy
    Happy Birthday Dave’s son. 😀
