Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › AEG dishwasher door is losing spring tension
- This topic has 6 replies, 2 voices, and was last updated 17 years, 8 months ago by
MrOtford.
July 31, 2008 at 10:12 pm #38455
MrOtford
ParticipantThe mechanism which prevents the door of my built-in dishwasher falling open when the catch is released seems to be losing it’s tension – if such a thing is possible. Symptoms are that the door now opens much more easily once the catch as released than it did when new – approx. 4 years ago. This has been noticeable in the last two weeks or so.
A better description of the behaviour of the door goes like this: upon releasing the catch, the door opens much quicker than expected – i.e you feel as though you have to support it to prevent it crashing fully open. At about 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} open, i.e. door open 45 degrees, resistance to the rate of opening increases and the door slows to its normal rate of opening.
So, do whatever supports the door in a dishwasher have any adjustment?
It’s an AEG unit if that makes any difference.
TIA and apologies if this is a much asked (and answered) questionRichard
July 31, 2008 at 11:31 pm #258955Penguin45
ParticipantRe: AEG dishwasher door is losing spring tension
Model number………….. pNc would be better.
August 1, 2008 at 9:15 pm #258956MrOtford
Sorry. Thought it better to wait for requests for further info rather than flood the post.
It’s an AEG Favorite 64070VIL PNC 911986009/001 Type 911D96-2T
RichardAugust 1, 2008 at 11:30 pm #258957Penguin45
You’ve probably lost one of the door springs. Unfortunately, the only way to check is to drag it out and remove the side panels to see what is going on.
August 2, 2008 at 11:02 am #258958MrOtford
Penguin45 wrote:You’ve probably lost one of the door springs. Unfortunately, the only way to check is to drag it out and remove the side panels to see what is going on.
‘s what I feared. Lost as in broken or as in unhooked. The later would seem unlikely.
Spared part?
Hopefully it isn’t as heavy as the (AEG) washing machine that required extraction a month or so ago so that I could tighten the cold water feed connection.
Richard
August 2, 2008 at 4:02 pm #258959Penguin45
Door spring – 1525666-01/0
Hinge kit – 50282093-00/9 (Well, you never know what you’ll find)The springs can break and the hinge mechanisms can distort.
August 2, 2008 at 6:17 pm #258960MrOtford
Penguin45 wrote:Door spring – 1525666-01/0
Lovely!
Richard
