AEG DISHWASHER F640701M
  • #54998
    kevinlewis
    PNC 911235215-00
    SEMI INTEGRATED. NOT HEATING.
    checked the control panel pcb and found a burn mark at the relay. too burnt to solder.
    searched AEG WEBSITE AND IT SHOWS PART NUMBER 1111437-12/3. IT STATES THAT THIS PCB IS NOT CODED AND WOULD REQUIRE A SPECIALIST WITH THE CORRECT SOFTWARE.
    DOES THE SPARE PART COME WITH A CODING SEQUENCE LIKE THE NEFF OR BOSCH MACHINES?
    #321665
    Re: AEG DISHWASHER F640701M
    Desolder relay and put new one in?
    Mike.
    #321666
    kevinlewis
    Its possible. I would normally send similar pcbs for refurbishment or credit. Its not a simple dry joint. I’d have to use a strapping wire, then it may not be successful.
    #321667
    kevinlewis
    I would like to know about fitting a new pcb. Have you heard of this software download before?
    #321668
    Washman
    According to TDS part no 973911235214013 is the one you need and comes configured.
    Mike
    #321669
    kevinlewis wrote:Its possible. I would normally send similar pcbs for refurbishment or credit. Its not a simple dry joint. I’d have to use a strapping wire, then it may not be successful.
    I’ve done this on a Bosch where it had blown a hole about 8mm dia. and succeeded.
    Mike.
    #321670
    kevinlewis
    I rang Distripart who were most helpfull. They have given me the correct part number for a configured pcb. it was cheaper than the unconfigured. Its up to the customer now, but I’ve leart something.
