Re: AEG Dishwasher Favorit 50730
It depends on what caused it in the first place. The only thing you can try is to turn off the water supply to it and disconect the fill hose from the tap and then simply re-connect it and turn the water on again. This releases the pressure on the anti flood valve and may cure the problem for now but not the original problem so try the wash programme again and keep an eye on it. Always ensure your filters and the sump under the filter is clean and free from any food debris. There are many versions of this complex machine and we would need a product code to advise further.
Dont attempt to remove any panels from the dishwasher without unplugging first.
If you post up your post code I am sure one of us could visit you before Xmas.
