Re: AEG Dishwasher having problems
Hi Adam,
Flood protection activated – the base tray is full of water and the float switch has over-ridden the programming.
First step is to get rid of the water. I would suggest that you get the machine removed from the housing, then remove the decor door. Once you’ve done that, you can remove the front lower cover and side panels and have a look at what’s going on. With the power off and some towels down, tip the machine to one side to drain the water in the tray, the machine should then re-set and become functional. If you have an adequate length of fill hose, run the machine. Using a bit of caution, look under the machine carefully – you’re playing spot the leak. A torch will help.
BTW, it’s £50 for the first hour down here in Leeds.
See what you can find and report back.
