FAVORIT 35085VI 911939222
This dishwasher keeps leaking intermitantly from the seal at the bottom of the door (but not when i test it). It has had a new seal fitted and when tested, with the door casing off, you can see the seal and steel troth.The water slightly splashes under the seal when washing (which i think is normal, but dose not overflow. The water level in the machine seems ok and ive checked the pressure switch tubes are clear.It goes through a complete wash with no errors but leaks “about half way through a cycle”. Could it be over filling on the rinse? Or releasing too much rinse aid causing suds? Im a bit stumped with this one!
Any ideas please?
Subs
