AEG dishwasher module setup?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG dishwasher module setup?
  • #84881
    Ray9500
    Hi all,
    I have a F44050VI i’m trying to replace the control unit on, the replacement 973911234997006 is different to the original in size and supposedly preconfigured although the wiring is the same.
    When you switch on its completely dead although there is power to the control unit. AEG customer service say there is a setup procedure to follow on these once fitted, I’ve not heard or read anything on this?
    Apparently involves switching on and opening and closing the door?
    I can’t get any life out of it and have replaced the new module in case it was faulty, the PNC number is 91123499700.
    Any help greatly appreciated!
    Ray
    #427071
    Re: AEG dishwasher module setup?
    checked part number of configured board
    97391123 49 97-00 / 6
    have pm’ed you manuals
    Ray9500
    Many thanks Dave, much appreciated.
    I’ll update results as soon as I get to grips with it again 🙂
    #427073
    Ray9500
    Quick update, nothing in the manual regarding any setup procedure on a configured module.
    I fitted an older module and it all worked fine, on contacting Electrolux customer service and explaining the modules they were sending me are unconfigured i got this: ‘The parts we have sold to you are in perfect working order and have been
    tested in Europe and we do not have any problem with our stock’
    Very helpful!
    Anyhoo, thanks for your help Dave 🙂
    Ray
    #427074
    thats like saying they are perfect and never make a mistake
    i can understand their position have seen the problem at my local wholesaler years ago. he used to give me the fauly modules to test and 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} were ok and some of the rest were blown through wrong connection
    Criscold
    Hi Ray
    I had the same problem a couple of years ago on this module, after checking the wiring it turned out to be the socket on the new board A1-A2 was reversed and had to fit the plug upside down to get it to work
    Worth checking
    Colin
