Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG DISHWASHER NO HEAT
- This topic has 9 replies, 6 voices, and was last updated 10 years, 6 months ago by
bruce118.
September 16, 2015 at 7:30 am #86114
bruce118
ParticipantAEG dishwasher F88020VI. PROD NO 911934605/06
The above dishwasher seems to heat the first time you try it then will not heat any time after that. I intially checked the heater OK. then replace the control board.
This made no difference. Have since changed the heater and connections, the Ntc also.
Checked the wiring and the pressure switch. Found no other faults. No earth faults either. I am now scratching my head, has anybody had this fault ?
Thanks. BruceSeptember 16, 2015 at 11:26 am #430327DASLTD
ParticipantRe: AEG DISHWASHER NO HEAT
Hi Bruce , if you let me have your email address ill send you the service manual with test programme.
Simon
February 2, 2017 at 10:14 am #430328bzz67
Did you ever get to the bottom of this problem? We have a very similar problem with one in our workshop right now and its starting to drive us mad.
ThanksFebruary 2, 2017 at 10:24 am #430329Criscold
Do you get any fault codes on this or have you been into diagnostics ?
February 2, 2017 at 5:46 pm #430330bzz67
i have got into what i think is the diagnostics and got 13 flashes of the end of cycle light. The model is FAVORIT40010VI pnc:911935627
Its a intermittent heat problem and its getting the better of us at the moment. Everything checked out ok so we replaced the pcb, even wiring, but still no good.
Any help/ ideas would be good (If not, I’ll try the hammer on it)February 2, 2017 at 7:05 pm #430331Criscold
You have mail
February 3, 2017 at 8:41 am #430332bzz67
February 3, 2017 at 10:48 pm #430333smartin
i had one which turned out to be a sticking pressure switch.
February 4, 2017 at 9:42 am #430334grooster
I’ve had this problem in the past with the Electrolux group dishwashers two or three times now, not sure if its the identical model or not, but it turns out to be the motor not running fast enough. It sounds fast enough. Somebody on here warned me about it and true enough it worked.
February 8, 2017 at 12:15 pm #430335bzz67
Thanks for all your help and input on this, but grooster wins the prize…..circulating motor sorted it. If only it wasn’t the last thing we tried. But in our defence, it did seem to be running ok and up to speed. So how would you diagnose that on a intermittent heat fault?
Anyway, UKWG saves the day. Thanks again -
