It could be the heater relay on the PCB breaking down under prolonged use – the quick wash uses that relay only for a short time. The other cycles (being much hotter) may not heat enough but the cycle will progress through. Look for weak cracked solder joints around the relay pins on these modules. Heaters tend to work or not as a rule of thumb.
