Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG Dishwasher over filling
- This topic has 8 replies, 6 voices, and was last updated 3 years, 9 months ago by
funkyboogy.
July 4, 2022 at 5:24 pm #100973
funkyboogy
ParticipantFSB42607Z 911 535221 00
TRIED THE LITTLE PRESSURE SWITCH BUT IT STILL OVERFILLS NO BLOCKS IN THE PRESSURE HOSE ETC ETC
WHEN YOU OPEN THE DOOR IT ALL STOPS – BUT IT STILL FILLS, BIT WEIRD
ANY POINTERS APPRECIATED
cheers ally
July 4, 2022 at 8:01 pm #482882electrofix
Moderatorcould be a failed triac on the board
July 6, 2022 at 10:01 am #482883funkyboogy
Participantcheers dave i was starting to think that myself – does seem an odd issue
ally
July 7, 2022 at 5:07 pm #482884hebegebe
ParticipantDoes it continue to fill when the power is removed? If so the Aquastop valve is faulty. Otherwise as Dave says, it’s a board fault. Graham
July 7, 2022 at 5:12 pm #482885hebegebe
ParticipantIncidentally, I like to force a bit of water through the hole where the little pressure switch connects (Length of rubber hose and a syringe!) just to make sure that the pathway is clear into the sump. I’ve had the air reservoir clag up, reducing or blocking ability of the pressure switch to sense the water level.
November 21, 2025 at 5:29 pm #482886twicknix
ParticipantI have similar but it fills and drain, when you quickly open the door, you can see the water spout from the airlock chamber and it stops. I can’t locate pressure switch, I am rather annoyed that I can’t seem to feel it or locate it. What is worse that the dishwasher is less than 6 months old and the owner didn’t register the machine (I supplied the dishwasher, installed it and told the customer to register).
November 21, 2025 at 7:00 pm #482887electrofix
Moderatoryou dont need to register to get your guarantee just a proof of purchase
if you post model and PNC will look up tech
November 23, 2025 at 12:42 pm #482888Hollytree_Technical
ParticipantDecember 1, 2025 at 11:04 am #482889boselecta
Participantthe most common cause for overfilling is the pressure tank getting blocked with grease.
they can be a pain to clear out as the pressure biottle is welded into the sump but with a flexible bit of wire / hose you should be able to clear the pressure bottle.
It only takes a little bit of grease to block them, rubbish design. -
