Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG door gasket problem
- This topic has 9 replies, 6 voices, and was last updated 20 years, 6 months ago by
rocker.
October 7, 2005 at 3:51 pm #12429
rocker
ParticipantHaving problems fitting door gasket to a AEG 91400209601.
removed front cover, there is a metal weight fitted around the drum but it is hard to get my fingers around to install, cant remove weight as its fitted to front of outer drum. and inserts are spread.
as any one fitted a door gasket to one of these, if so can you give me any advice..please
cheers john.October 7, 2005 at 4:00 pm #149647Penguin45
ParticipantRe: AEG door gasket problem
It’s basically the same as any modern Zanussi – if anything it’s easier as the cabinet front comes off.
October 7, 2005 at 4:08 pm #149648Martin
Once you have the front panel off, lay the machine on its back. Then smear loads of washing-up liquid on the seal lip, place it in position and with finger and thumb action follow the seal around holding it from the outside as well as the close guard inside applying equal pressure all around the 360 degrees. Once in place, invert the seal towards the inner drum and run the spring around!
Refit the top hose and away!
Tricky but the washing-up liquid is your lifesaver! 😀
October 7, 2005 at 7:53 pm #149649rocker
Thanks Penguin and Martin for advice have tried what you suggested apart from laying machine on its back, will give this a go.
October 7, 2005 at 9:28 pm #149650Dave_Conway
Rocker, read your PM’s please 😀
October 12, 2005 at 9:16 pm #149651whiskeyjack6058
Washing up liquid is the saver, if the front doesnt come off, remove the door, and i find that packing something between the seal and the weight to stop the spring coming off whilst you try to fit it helps.
October 12, 2005 at 11:37 pm #149652Penguin45
I have to say that any sort of lubricant makes the gasket impossible to fit. Like the spring, it has to be stretched to fit and I have never succeeded. The spring can be jammed with a 10mm deep socket trapped at about 10 o’clock. Goes on reasonably easily.
I think Jim’s got a prototype spring fitting widget in an earlier thread. I’m sure he’ll tell us.
October 14, 2005 at 12:25 am #149653leavemetogetonwithit
Penguin45 wrote:I have to say that any sort of lubricant makes the gasket impossible to fit. Like the spring, it has to be stretched to fit and I have never succeeded.
Penguin I don’t understand. Oh,I see, you’ve never succeeded using the lubricant.
I did one today(LW1259),having read your post beforehand, I didn’t put any lube on. It wasn’t too difficult, using bits of wood to keep the “on” stretches in place. I noticed there are “teeth” around the edge/lip of the tub, presumably to keep the seal from slipping round.Lovely machines IMO except for having to keep changing from torx to Philips and back again. (Short focus going a bit these days,perhaps too much screen radiation).
Mike.October 14, 2005 at 1:57 am #149654leavemetogetonwithit
Incidentally, why have I had a spate (2) of call outs to these seals with a torn lower lip recently?
Mike.October 14, 2005 at 8:33 am #149655Dave_Conway
Coincidence I expect. Normally caused by overloading and customers dragging the washing out at the end and something catches the seal.
And dogs biting them for some strange reason 😕
