aeg door problem
  • #20625
    andyitfc
    got at least a 20 year old aeg 2050 lavamat where the door just wont shut the door handle and striker look ok and the door lock works if i click it over with a screwdriver problem is not sure weather to order lock or handle kit although can only find d/lock at homespare which r quite expensive but cant find handle and striker anyone konw of this being common problem when they were in there hayday
    #187754
    cab
    Re: aeg door problem
    hi yep door hook can wear and spring looses tension suspect parts would be obsolete. Started manufacture in 1982!
    cab
    #187755
    Washman
    No parts shown on TDS
    Mike
    #187756
    Masterpart still have that spring – AG6001 @£0.49
    andyitfc
    thanks for advice
    #187758
    pmb
    I had this problem ,
    I shaved some plastic off the striker where it touchs door, so it closed more onto the interlock
