AEG Double oven D8800-4-A overheating
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Double oven D8800-4-A overheating
  • #94900
    Thirl
    I Have a AEG Double oven and the bottom element of the main oven doesn’t stop heating up consequently burning food. Even when the grill is selected the bottom of the oven heats up?
    Does anyone know what it requires to fix this problem?
    #458692
    it looks like you oven is controlled by a circuit board. the chances are one of the relays controlling the lower element has stuck. the cheapest way to possibly cure it is to find which relay has gone faulty, obtain a replacement and solder it in
    if you cant do this then I suspect you need a new control board
    Thirl
    Thanks for your reply Dave
