AEG drum spider bolts? Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG drum spider bolts? This topic has 4 replies, 4 voices, and was last updated 14 years, 12 months ago by iadom. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts April 12, 2011 at 1:49 pm #62194 iadomModerator I have a drum support job to do on an AEG Li2700VIT, integrated washer/dryer, I know you are all envious. :rolls: Not done one before ( have done bearing changes though ). I was just interested to know if the bolts that secure the spider to the inner drum are likely to be a problem or will they remove easily? Jim. April 12, 2011 at 2:10 pm #349167 MartinParticipant Re: AEG drum spider bolts? I don’t believe so Jim, just regular 13mm bolt heads IIRC? April 12, 2011 at 3:30 pm #349168 AlexParticipant Re: AEG drum spider bolts? Warm the bolts up first, make sure you have a pristine spanner, preferably with 6 flat faces, and go at them gently. Alex April 12, 2011 at 4:43 pm #349169 iadomModerator Re: AEG drum spider bolts? Messages received and understood. 8) Its all work but its one of those that you don’t feel that upset about if they decide against. 🙂 Jim. April 12, 2011 at 11:37 pm #349170 leavemetogetonwithitParticipant Re: AEG drum spider bolts? 10mm if it’s a normal Lux spider. Like Alex says, easy to round them off if you don’t go careful. Best to have a spare one or two available. Mike. Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
