AEG dryer E40
  • #94803
    rolf
    Hi.
    Hope someone can help.
    I’ve got an AEG dryer T61275AC. book in showing E40 or EH40 anyone got any pointers before I go out.
    #458399
    bit difficult this one as these are possibly 2 different codes
    the 4 series alarm codes of which there is only 1 is E45 and is a door problem
    EH codes on the other hand normally are power issues
    EH4 alarm is the zero watt failure. Dryer will function normally but will draw more power on standby
    can email you stuff if you need it
    rolf
    Yes please.
    #458401
    will need your email add
    rolf
    rolf
    Thankyou for that Dave I really do appreciate it. There’s no mention of error codes in there. The lady said it it was a eh40. I assume its a pcb problem (zero watt failure)
    #458404
    chances are if you put it into engineering mode you will get a different answer. codes are different that the customer sees.
    I would guess customer sees E40 but go into engineering and you get e41 or E42 or E43 etc not E40
