Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG dw – F50860M – flashing on startup…
- This topic has 6 replies, 3 voices, and was last updated 16 years, 1 month ago by
gandh1.
February 10, 2010 at 7:21 pm #52406
gandh1
ParticipantHello wisened ones,
got the above – pnc 911371070-00 that wont do anything, except flash all the lights quickly. normally connect have the service manuals uploaded for aeg and zanussi, but this pnc and model is not listed. have tried the other diagnostic access procedure for other similar models but doesnt seem to want to do anything because before you get the chance to release the buttons, all program leds start flashing again (simultaneously)
wondered if anyone had any service manual information for accessing diagnostics for this particular model in case im not doing it correctly!
pps customer is urgent for this to get sorted before the weekend, i cant even find out the price of a new board until probs end of the week as connect havent listed it, and it seems ot take 2-3 days for a pne to clear now, so if anyone can provide the control module part no it would be really appreciated!
February 10, 2010 at 8:02 pm #311655Penguin45
ParticipantRe: AEG dw – F50860M – flashing on startup…
Something in your in-box.
February 10, 2010 at 8:33 pm #311656gandh1
merci beaucoups
February 10, 2010 at 11:58 pm #311657gandh1
same test procedure as what i have already tried it seems
constant flashing of all lights
unable to reset program
unable to enter diagnostics – the first 3 leds light up but never start to flash, and then the secodn you take your fingers off it reverts back to all leds flashing.
oddly enough, if you just switch it down and do led 1 + 3 at any stage during the flashing u get the frist 3 leds light up.
hold down sw1 on its oen and all 5 leds light up
hold down sw2 on its own and all the rinseaid/salt/etc leds light up.at no stage is there a display on the lcd panel.
no component appears open circuit or faulty – have manually gone thru all connections, testing with each comp disconnected and then tested after reconneciton.
incidentally it was full of sweetcorn kernals and pepper husk, but ive checked clearness in every channel. the only liquid in it is in the salt/regen chamber.
any ideas people, anyone come across this before either? cos im at a loss, really hope its not the pcb as thats almost £200 inc vat – trade. GULP.
HELP!!!!
February 11, 2010 at 11:36 am #311658gandh1
also has no visible burn outs on pcb.
is this model prone to smegstyle interferance from the suppressor and/or dispenser corrupting the board?
February 17, 2010 at 7:27 pm #311659bigchrisoioi
pcb !!!!..i am afraid
February 24, 2010 at 7:35 pm #311660gandh1
it was indeedy.
went to emw.
came back
superb service.
fitted and ran full diagnostics, no component failure that could be found, so ran it thru 3 times on 3 progs, delivered back and now chugg chugging away.
so thank you to the kind person at emw that made another persons day. still baffled as to why it went tho, because emw couldnt really explain what had to be done… 😯
