went to this today its not heating would have to take it out to check heater but big job as got laminate flooring is it likely to be the heater or is there anyother things likely to cause it on this model cheers?ie pcb
Would definitely check pcb first. I think it’s behind fascia. Have had relay dry joint on Zanussi a couple of times. If not that, tube type heaters tend to go. Can probably be checked from pcb wiring. Try Connect for circuits.
Mike.
