AEG E64KL Hob & Oven
  • #10057
    Brains
    Has anyone got a set of drawings that I could use for the above? Customer has broken the hinge on the control panel, two rings not working, underside wiring (at the control panel) shorted against the frame (tripped the MCB) as the control panel dropped down (when the customer broke the hinge).
    Also need the part numbers etc for a bunch of parts once I have determined what I need to fix this.
    Any help would be appreciated.
    #138103
    Dave_Conway
    Re: AEG E64KL Hob & Oven
    On the way Brains 😀
    Just the oven details though, the hob is a seperate model even though it’s controlled by the oven 😉
    #138104
    Brains
    Many thanks – I need the drawings for the control panel (unless this is integrated within the oven assembly)
    Do you need my e-mail address ?
    Regards
    Mike
    #138105
    Dave_Conway
    Brains wrote:Many thanks – I need the drawings for the control panel (unless this is integrated within the oven assembly)
    I’ve sent the whole PDF file, it’s the oven complete.
    Brains wrote:Do you need my e-mail address ?
    Nope, I have it, but I had to resend as your an AOL user and AOL don’t like certain email suffixes (such as @ukwhitegoods.co.uk for instance), no idea why 🙄
