Aeg el..lavamat turbo L16830, trapped item.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Aeg el..lavamat turbo L16830, trapped item.
  • #77438
    jfwp
    Model L16830
    Serial 914602122 01
    Washer dryer
    I accidently left some coins in with washing and I think one is stuck between the drum and the drum housing.
    I have read that if you can remove the drum paddle there may be a hole big enough to get the item out. I havent managed to do this as I cant find out how to remove the paddle or if its even possible on this model.
    Can it be done? Or is there another way to get to it?
    Thanks,
    James
    #402186
    Andy jones
    Re: Aeg el..lavamat turbo L16830, trapped item.
    Don’t think you will get the paddles off very easy. If you’re lucky the may drop into the filter to be removed
