AEG electric oven goes off after 15/20mins
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG electric oven goes off after 15/20mins
  • #92236
    jas1066uk
    Hello,
    Model: AEG B1180-1-M
    Oven switches off after 20min had it for 4 years, No heat, no fan and no light. Any ideas.
    Thank you for any help
    #450656
    Re: AEG electric oven goes off after 15/20mins
    Check the thermal cutout (aka TOC). Isolate power before pulling out and removing panels :zap:
    #450657
    jas1066uk
    Got the back off power off, what does it look like. I am okay with electric. Light inside went off too.
    #450658
    jas1066uk
    When its cooled down should the thermal switch, switch the power back on? IS this the same as Oven Cooling Fan Control Thermostat Thermal Cut Out? Looks like two one with a long silver wire..and how to check if working.
    #450659
    do you have the prod number should be on the rating plate
    The ‘overheat protection thermostat’ (as AEG refer to it) is likely attached on the top adjacent the cooling fan. Usually constructed of metal and white porcelain with one wire in, one out.
    One question for you : Does the cooling fan work when the oven is on?
    #450661
    jas1066uk
    Cooling fan on top does not turn ie not blow air in normal use. Was looking at the ZN limiter as part to buy if not what should i go with. What’s the part number i need for the overheat protection thermostat?
    PNC: 944-181-727
    #450662
    Overheat stat : 3302081058 available at this web site shop 😉
    The cooling fan needs checking out as that is the reason the oven shuts off!
    #450663
    jas1066uk
    Thanks Martin. What’s the part number for the cooling fan.
    #450664
    if the cooling fan is not working is may be the fan itself or its not being turned on
    we can get you the part number for the fan but make sure it has failed before you swop it
    there are also 2 cooling fans fitted one fitted up to 14/10/2001 and the other fitted from 15/10/2001 the later one has part number 8996619270995
