AEG Electric oven – grill turning off after a while.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Electric oven – grill turning off after a while.
  • #89549
    treebs
    The oven in a house I have recently bought is not working properly. The oven part seems to be fine but whenever I use the grill it turns off after a while. I searched the forum and noted the common problem with the fan cutout switch. I have replaced this and it hasn’t made any difference. I have also tried swapping the white wires over. The replacement part had no markings on either wire.
    Should the fan come on straight away? I cannot hear it or feel any air movement apart from a little bit of heat when it is on. I have also tried spinning the fan from above with the panel removed. It seems to move freely.
    The details of my oven are:
    Model number U41116
    Type No 91E1D01KD
    Pro No 944171457 01
    I would be very grateful if anyone could help. Also I have a relative who is an electrician. He will change parts but he isn’t experienced with ovens and such. Its more of me asking him to change a specific part which he will do.
    Thanks in advance.
    #441691
    treebs
    Re: AEG Electric oven – grill turning off after a while.
    Here is a photo of the top of the oven if its of any use:
    http://email.photobucket.com/wf/click?u … Coow-3D-3D
    #441692
    bazza500
    when you say you swapped the white wires over. It looks like it has black wires to me.
    #441693
    treebs
    I meant the white wires coming from the part labled “ZN limitor”. This seemed to be a common problem from what I have researched.
    #441694
    swopping wires wont cure it fit a new one
    its a thermal relay that turns the fan on after a few minutes and let it run on after the oven is turned off
    bazza500
    What is the part number of the part you have replaced?
    #441696
    treebs
    Thanks for the help. The part number of the item I have replaced is 3872079029. Just to be clear I replaced it and it still didnt work. I think tried swapping the white wires over.
    #441697
    bazza500
    I would check the continuity of the fan motor next.
    #441698
    agree with bazza provided you have not made a wiring mistake in fitting the new one
    just to clarify
    2 wires feed a heater inside the switch (in your case you have connected the white wires )
    the other 2 wires are a switch (blue wires in your case) in other words if you joined up the 2 blue wires the fan would run all the time
    i dont know if you have the colours correct but i think you have correct connections
    1 things to help
    since the unit has a small heater it will get warm when energised
