Re: AEG Electrolux E9 cooker fault D98000VF 948522155 Cerami
Would get them to double check the cable connections are correct, one of the plugs can go on incorrectly from memory, for instance there may be 9 connections on the socket of P.C.B but the plug is 8 way, if its not on the socket correctly the way the original one was it will give error code.
Small data cables between the P.C.Bs on these are the most tempermental & give errors, sometimes making you think its more serious a problem. But if board was burn’t out then thats in need of replacement.
