Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › AEG Electrolux T3580. Vibration when running
- This topic has 4 replies, 2 voices, and was last updated 12 years, 10 months ago by
jerry111.
June 8, 2013 at 9:33 pm #75773
jerry111
ParticipantHello all. 🙂
I’ve had this machine for around 3years now, it’s worked perfectly untill recently when there is a loud ‘vibration’ coming from inside the machine. Different loads make no difference to the noise. It appears to be getting worse.
I owned a Servis dryer years ago that suffered from failure of the felt bearing pads, this made the unit vibrate before you got metal to metal contact between the drum inner/outer. Is this AEG unit similar in this respect?
I’ve repaired most of my washers/dryers over the years and am aware of the safety issues involved.
Any help or advice would be appreciated. Thanks. 😉 JMJune 8, 2013 at 11:58 pm #396088electrofix
ModeratorRe: AEG Electrolux T3580. Vibration when running
there is an idler pulley on the belt could be this or one of the fans out of true
June 9, 2013 at 10:11 am #396089jerry111
ParticipantRe: AEG Electrolux T3580. Vibration when running
Hi Dave,
Thanks for the advice, will post again when I’ve found found out what’s gone wrong.Regards, JM.
June 13, 2013 at 9:21 pm #396090jerry111
ParticipantRe: AEG Electrolux T35850. Vibration when running
Hi all,
Thanks for your advice Dave. Finally got a chance to look at the unit today.
What’s causing the noise are the two roller tyres that support the front edge of the drum. As you look at the rear of the unit, it’s the one that’s on the left (nearest the motor) that was making the most noise. I’ve swopped them over and the noise is much reduced. I know that this is just a temporary measure and I’d better replace the pair of them.They are 69mm Dia by 12 thick. I’m not sure if e-spares or Ransoms stock them as I’m not sure what the correct trade name is!
Does anyone know of a stockist?
Regards, JM.
June 14, 2013 at 9:59 am #396091electrofix
ther are actually 3 machines with the same model but have different production codes
if your is 916095202/00then you pulley looks like
part number 1364059004
email site shop to see if they can supply
