Aeg electroux 14840
  • #98653
    fasetester
    What would be the worst case on this washer dryer code E10 thanks fasetester
    #473231
    fasetester
    Or a list of thing to check does it relate to a water problum thanks
    #473232
    have you got the full model ./ prod no
    as far as i know all E1* codes are filling issues
    dave
    #473233
    Hollytree_Technical
    If it comes up on a dry cycle then take a water valve with you as in my experience it is almost always the dryer valve going open circuit after a few minutes use.
    Jem
    #473234
    fasetester
    Prod no 914605004 00 AEG Lavamatic turbo model L14840
    #473235
    fasetester
    Works for about 30min then stops press start and work again
    #473236
    fasetester
    Could this be a pcb fault thanks fasetester
    #473237
    this is E11 fault which is the wash one. you would have to go into diagnostics to find out if its E11, E12 or E13, E10 is what the customer would see in each case
    fasetester
    Thanks dave how do you go into diagnostics on this AEG machine fasetester
    #473239
    pm me your email add
    sorted
