AEG-Electrulux
  • #75080
    mccoy2876
    Hi All
    Got an AEG-Electrolux condenser Tumble Dryer and after switching it on last week and starting up it ceased operations. Now it’s DEAD. Their is no light on the front panel. I have checked that power is getting to the dryer. Before. Go dismantling the dryer any help on what I can check out for? Is their an internal fuse that may have blown? Would the thermostat have gone, and would cause no power to get into the dryer?
    Your help is greatly appreciated
    #393794
    Specialist01269
    Re: AEG-Electrulux
    Do you have a Multimeter & know how to use it for testing ? The thermostat going wouldn’t cause your machine to be Completely dead.
    #393795
    mccoy2876
    Re: AEG-Electrulux
    I can get one from work tomorrow. Shouldn’t have much of a problem using it, nevertheless I can ask a collegue(electrician) to come with me. I did check with a tester for elec current and found current going up the cable into the appliance. Dismantled top and front panel but couldn’t see any type of fuse which may have gone.
    I look forward to your reply.
    #393796
    Specialist01269
    Re: AEG-Electrulux
    Hi: No need to carry out any live testing, you should be able to localise the fault easily enough using resistance tests. Doubt that there’s a fuse inside to blow, the 1st thing I’d check would be the door safety switch. Have you got a model number for the machine ?
    #393797
    mccoy2876
    Re: AEG-Electrulux
    Thanks for the prompt reply. The model is Electrolux EDC67150W. What I seem to recall is even if the door was open the start/stop button would flash n green.
    #393798
    mccoy2876
    Re: AEG-Electrulux
    Would appreciate any more help, how do I check the door switch, or any other part of the dryer?
    Thx
    #393799
    Specialist01269
    Re: AEG-Electrulux
    Hi: Will see if I can find the manual for it & go through it with you.
    #393800
    mccoy2876
    Re: AEG-Electrulux
    Just checked door switch and its ok. Dismantled front panel but don’t know what to check for?
    #393801
    Seamy
    Re: AEG-Electrulux
    A tester wouldn’t find current going up a cable, you need an ammeter for that, a phase tester will only show that there is a live connection to the appliance, you need both a phase & neutral for the appliance to work.
    Anyhows its likely the p.c.b is gone on it, post the model & or PNC (9digit) code of appliance so someone can help you with more specific details.
    #393802
    mccoy2876
    Re: AEG-Electrulux
    Thx for the help. Although my terminology may not be the correct I was told by my mate that he checked for continuity and used an ammeter n found all correct, atleast the hints he could check.
    Model No. EDC67150W Prod No. 916096087-08.
    Thanks again for the help
