AEG error C6
  • #78993
    Pnc: 914002406/00
    Customer just phoned, call booked in.
    Fault code relates to pressure switch, says the pump filter is clean, anything specific I need to be aware of? The last time I had a similar problem on a Zanussi reporting ‘incongruence’ I seem to remember changing both switches without success, twas several years ago though. :clown:
    TIA.
    Seamy
    Re: AEG error C6
    Heater or motor earth leakage can cause these erroneous faults, as does dust & condensation on the circuit board. Double check cabling to pressure switches & pressure vessel, hose pipe also.
    #407546
    Re: AEG error C6
    Thanks, will check all those out if nothing obvious shows up. 😀
    #407547
    Re: AEG error C6
    Called this afternoon, everything meggered out perfectly. no obstructions or holes in pressure hoses or chamber.
    A gentle blow into the pressure switch revealed rather ‘woolly’ sounding contact switches.
    Set it to wash and it worked fine.
    She did say that it often worked for a while before corpsing and occasionally didn’t seem to spin that well.
    Going to try a new pressure switch but they seem to be out of stock everywhere. :rolls:
    listed as 1105711004, reportedly superceded on some sites to 110571012.
    #407548
    don
    Re: AEG error C6
    Hi Jim
    1105711012 is in stock at Connect. Dave in the shop should be able to get it 😉
    Don
    #407549
    Re: AEG error C6
    Thanks Don, will get onto him. 🙂
