Hi all
I have a aeg santo 3600kg that needs a new freezer door seal. there is one listed on tds disc no 8996711611526 but its £35+.
Does anyone know how this fits as no screws in door, does the linner prize of or is it a stick on joby 😯
bit worried about wasting £40 on something that wont fit or stay fitted for long 😥
Very often the seal is shown on the diagram but it’s moulded in at the factory, it has a part number but you’ll need a whole door more often than not 🙁
Paul, some of the AEG door seals are of the type where you cut off the old one and the new one has a stiff inner lip which lots behind the remaining edge of the original. If you look at the s3600 pnc number 62151197100 it has a bulletin about this.
Easy job but it definitely needs the superglue to hold it in place. 🙁
