AEG F34030V10 3 flashes.
  • #94043
    Geoff1312
    hi all.
    Called to above dishwasher it drains for a while , stops then flashes r/h light 3 times and carries on doing just that. There is no water in base and you can hear anti flood click when triggered manually any ideas please , thanks in anticipation
    Geoff 1312.
    #456259
    Re: AEG F34030V10 3 flashes.
    fault lists as
    Water leakage from the tub – sump and various
    connections (pump, upper spray arm duct etc.);
    floating sensor blocked mechanically; microswitch
    faulty; fill solenoid blocked mechanically; circuit
    board faulty (solenoid triac short-circuited); wiring faulty
    there are 30 machines with the same model number ( should always post Pnc No) so will pick one at random and pm you a manual
    Geoff1312
    Hi Dave.
    PNC is 91153904605 there is no waterin the base and float and switch are functioning ok.
    Regards Geoff.
