Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › AEG F34300VI0 – Flashing LED’s
- This topic has 7 replies, 2 voices, and was last updated 3 years, 3 months ago by
Techie_hobby1.
December 20, 2022 at 6:35 pm #101493
Techie_hobby1
ParticipantRecently above Dishwasher has gone faulty (Note** this is being posted on behalf of a friend)
When it is first turned on the LED next to Timer stays lit;
When try to run a cycle..
It appears to drain water;
Fills with fresh water (water is cold at this point)Note** can hear a quiet buzzing (possibly a solenoid)
Then nothing happens;
After a while it then drains but with no heat at all.No beeps are emitted only flashing LED’s which include the ECO 50degree and the Timer LED which continuously flashes (See short video sent to me)
[video]https://www.kapwing.com/videos/63a20017dbc5000111ed7a88[/video]
Does anyone have any thoughts please?December 20, 2022 at 10:04 pm #484962electrofix
Moderatorthere does seem to be a pattern to the light flashing but i cant count as your moving too much
think its 11 flashes then pause
December 20, 2022 at 11:29 pm #484963Techie_hobby1
ParticipantHi Dave,
As I did explain, it is a friends Dishwasher and they took and sent that video to me, so I cannot take a new one.
I have, however been able to use some video editing software and slowed that video down.The 1st set of flashes = 10 times
2nd set flashes = 13 times,
3rd set flashes = 13 times and
4th set of flashes = 13 timesThe 1st set might well have been 13 times as well, but the video didn’t pick up the first 3 out the 13.
December 21, 2022 at 1:57 am #484964electrofix
Moderatorbit odd because it says this fault code does not show unless in service mode
13 flash codes basically says main motor not running or cany detect main motor is not running
December 21, 2022 at 12:24 pm #484965Techie_hobby1
ParticipantHi Dave,
How do you get this in and out of Service Mode
I wonder if my friend (whom I know has been watching various YouTube video) has followed someone’s instructions and not realised what they have done.I am going to my friends tomorrow, so if you could provide me with a little guidance to the Service ~Mode then that would be kindly appreciated.
Could really do with the fault code list as well so that I can at least attempt to diagnose his dishwasher fault. He is hoping to have it working before Christmas
Thanks againDecember 21, 2022 at 8:03 pm #484966electrofix
Moderatorservice mode it normally easy to get out of. just switch off and on again. sometimes have to do this twice
December 22, 2022 at 1:21 pm #484967Techie_hobby1
ParticipantHi Dave,
So its as simple as turning on and off twice quickly.. this should put it in service mode and also take it out service mode.
But do you have the Service Mode details of various faults please.. (even a screen shot of these faults would be very much appreciated)Like I say, I am going over to his tonight for Christmas drinks, so can take a look at it with him later
Thanks againDecember 23, 2022 at 5:20 pm #484968Techie_hobby1
ParticipantHi Dave,
Managed to sort the dishwasher out.
Turns out that a bit of glass had found its way in where the filter goes and had dislodged itself, thus stopping the propeller from spinning.
When he was cleaning the filter the piece of glass must have found its way there and wasn’t noticed at the time.Anyway, after careful removal the appliance is now working properly.
Thanks again -
