AEG F34502VI0 Leaks into base tray
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG F34502VI0 Leaks into base tray
  • #92981
    Twoten
    I have looked at the above machine which went into anti-flood due to water in the base.
    Looking at the build up of slime in the tray it appears that this has been filling gradually over time.
    I dried and cleaned the base tray then run a test but there is no sign of water entering the tray. The inside of one of the overflow tubes clipped to the base of the sump had a small drop of water inside. Door seals appear to be OK.
    The PNC for this machine is 911539114/01 the pressure switch is mounted directly to the left of the sump so I assume the modification isn’t applicable to this one.
    Is there anything I need to check that could be the cause of a slow leak into the base?
    #452785
    Re: AEG F34502VI0 Leaks into base tray
    yes the mod is applicable. when modded the pressure switch does not move its the pressure chamber that’s modded in the sump
    check pictures from enclosed
    dave
    #452786
    Twoten
    electrofix wrote:yes the mod is applicable. when modded the pressure switch does not move its the pressure chamber that’s modded in the sump
    Thanks again Dave.
    I will order this in the morning.
